Case 2470 Questions
Mike S 806/H
04-19-2006 20:07:29
I bought a case 2470 today power shift is bad no 2nd or 3rd, Its a rough old tractor I think its a 1973 serial #8713474, Question is when you let the clutch out it's violent!!!! I tried to ride the clutch, nope do difference, then I tried reverse holy $#it even worse, dont want to try that again! Where can I get a repair manual for it? I know I will need one, looks like big job to repair. One good thing the engine was supposed to be rebuilt only around 300hr's on it, it's been setting for about 13 years,
430-WLPG
04-23-2006 18:50:56
 Re: Case 2470 Questions in reply to Mike S 806/H, 04-19-2006 20:07:29
The clutch is not modulating probably stuck valve in the control valve,and it's located under the floor board and may just be buried in dirt.The PS is a big job.Question if you push in the clutch in neutral does it make any bad sounds? If not it just has some worn disk and/or blown seals.To repair it you have to remove the engine,everything for the PS is done through that opening.
Mike S 806/H
04-23-2006 18:57:51
 Re: Case 2470 Questions in reply to 430-WLPG, 04-23-2006 18:50:56
when you puch in the clutch it just makes the enging sound a little different for a second, I was in a 4690 and it did the same thing, when I remove the engine do I have to remove the power shift housing or do I do it in the frame? thanks, Mike
