Temperature Gauge - Case S
CK from ON, Can
04-19-2006 15:51:37
On my Case S there is round gauge that I assume is a coolant temperature gauge. There is a long wire connected to it, that has a threaded fitting on the end. The threaded fitting has a metal bulb about 1" long by 3/8" diameter on the end. I assume this is some kind of a temperature sensor, but it just dangles there tucked out of the way. Where should this thing be connected? Also another of my Case S (a 1952 model)has no oil filter, is this how it should be or some 'modification'?
CK from ON, Canada
04-20-2006 17:57:22
 Re: Temperature Gauge - Case S in reply to CK from ON, Canada, 04-19-2006 15:51:37
Thanks Tis for the location, and all for everything else. I suppose the oil screen worked fro 50 some years and will continue to. I hope to see the two old Cases crank this summer.
tis24
04-20-2006 16:03:37
temp gauge is on the right side of water inlet on my tractor
Walt Davies
04-19-2006 22:51:49
The case tractor did not come standard with an oil filter it was an add on. About half of them have one and the other half don't.
Clean and check the screen in the crankcase when you change the oil in the engine its real easy and the gasket can be made from stock material that you can get at any auto parts store.
Walt
CK in ON, Canada
04-19-2006 19:17:59
I think I have noticed the triangular oil pump screen, only didnt know what it was. It that screen suffecient to filter the oil? If I get the machine running well again and put her to work should I add a filter?
tis24
04-19-2006 19:27:36
 Re: Temperature Gauge - Case S in reply to CK in ON, Canada, 04-19-2006 19:17:59
it has worked well for the past 50 some years just as long as you clean it regularly there shouldnt be a problem
the book says every 250 hrs to clean it with gasoline in a bucket i suppose some other solvent would work as long as it is dry when replaced
chris
CK from ON, Canada
04-19-2006 18:48:33
thanks for checking that for me, tis 24. I know the oil filter is in the can above the starter. One of my Case S has this can filter, and the other does not. The one without the filter is a 1954, is that how it was built, or has someone removed the filter assembly?
tis24
04-19-2006 19:04:54
 Re: Temperature Gauge - Case S in reply to CK from ON, Canada, 04-19-2006 18:48:33
on some of the older tractors in the s series there is only an oil pump screen on the left hand side of the oil pan it is sort of triangular with three bolts in it also if you have an s model you may have to raise the left front tire to get it out past the radius rod i dont know when they started putting the filter on the side so maybe this will help
chris
tis 24
04-19-2006 17:18:18
i have a 54 case sc i will look tomorrow where my gauge is placed and my filter is on the right hand side above the starter inside the can hope this helps
chris
