Clutch parts 830
TexasWren
04-19-2006 11:49:11
My clutch blew up last week. The throwout bearing carrier lost an ear, so it will no longer disengage (I think the bearing might have seized up, too). There's probably more wrong that I'll find when I split it. Case's price on the carrier is about $400. Just replacing the bearing is a lot cheaper. Does anyone know of a carrier from an 830 diesel that's being parted out? The serial is 8270927. Thanks!
Lamont
04-20-2006 18:38:40
 Re: Clutch parts 830 in reply to TexasWren, 04-19-2006 11:49:11
If you're not in a great big hurry, I'm parting out an 830 that should have what you need. I haven't split it yet. If you can tell me what all you need, I'll try to save you some serious $$$.
JarrodS
04-19-2006 22:27:59
Good luck on your search....I had the same thing happen to me on my gas 830...bearing seized up and one of the ears broke off...ahhh. Like you said I think that cost me about 400 bucks to replace.....easiest tractor I've ever split...to bad everthing so expensive once you get in there.
