S / VAC Headlight bar the same?
Brian in WA
04-19-2006 07:46:01
Does anyone know if the headlight mounting bar that hold a light on each side and mounts near the gas tank is the same for an S and a VAC. I have a S mounting bracket and want to put it on my VAC if it fits. Thanks
CK RICHARD
04-19-2006 18:33:13
 Re: S / VAC Headlight bar the same? in reply to Brian in WA, 04-19-2006 07:46:01
not only is the light bar not the same the lights are also a diffrant size
watsonsgotit
04-19-2006 14:51:42
The late va series tractors used a light bar that mounted in front of the gas tank much like the s series. They are not the same. The va series is basicaly a flat bar where the s series is a piece of angle iron that has some bends in it.
C. Amick
04-19-2006 14:00:04
No, the VAC lights mount on two separate posts down near the running board. I see the lights and posts up for auction on Ebay fairly often.
