930 trans starting trouble
Eagle claws
04-19-2006 07:25:22
My 930 with 8 speed transmission moves when i try to start it. Even with the clutch pushed in and the transmission in neutral, hi-low in S. Even if I had the tranny in gear shouldn't having the clutch pushed in disengage it. Anybody have suggestion.
DKase
04-19-2006 11:19:27
 Re: 930 trans starting trouble in reply to Eagle claws, 04-19-2006 07:25:22
I had a 930 do that when the PTO shaft was twisted off inside the input shaft of the trans. The chunks of shaft ground in so tight that they split the input shaft. Hope you find something simpler. DK
c hess
04-19-2006 08:43:13
Is your pedal free play correct? It should be noless than 1/2in or over 2 1/2 in.
