David Brown - siezed front axle pivot pin.
peter uk
04-18-2006 12:53:57
I'd be grateful if anyone could give me any tips on how to remove the pivot pin which is siezed solid in the axle (not the bushes). I've removed the securing bolt which passes through the axle and the pin and thought the pin would just pull out - wrong!!! Any help would be most appreciated.
peter uk
04-20-2006 23:51:14
 Re: David Brown - siezed front axle pivot pin. in reply to peter uk, 04-18-2006 12:53:57
Many thanks for all your suggestions and the time you took to reply. You've given me several ideas and I'll let you know how I get on.
Baz
04-20-2006 01:27:52
After heating and soaking in penetrating oil, use a slide hammer with a big weight. Worst case, fit a big cut off wheel to your grinder, sacrifice the two thrust washers and cut through the pin at each side of the beam, then press it out.
Elmer
04-20-2006 04:46:40
 Re: David Brown - siezed front axle pivot pin. in reply to Baz, 04-20-2006 01:27:52
I've had my fair share of those seized pins! I found that when you heat the tube up real hot you only have a minute or two to go at it with the slide hammer. Then the pin swells with the heat. I found that if you have a running water hose there to cool it back down and then heat the tube up again you will get more progress. Spent 3 hours on the last one i did. But your idea of the chop saw would work great too.
Walt Davies
04-19-2006 11:28:17
Use a rosebud on your acetalene torch and heat the axle. Or soak it with penatrating oil and wait for several days for it to soak in. Or use both. heat is the best bet. Don't heat the bolt heat the axle.
Walt
