david brown 1200,pto problem
d masters
04-18-2006 09:38:17
i have a 1200 david brown,replaced clutches and pressure plate,now i cannot get it to ongage the pto with engine running.i have to engage pto then start it on order to use the pto.what could be wrong anybody got an idea or had this problem before?apprciate any help.
Baz
04-20-2006 01:38:53
 Re: david brown 1200,pto problem in reply to d masters, 04-18-2006 09:38:17
Remove the inspection plate under clutch housing. Have someone move the pto lever while you look at the clutch. The thrust bearing carrier should be about 1/8" away from the thrust plate. If it a long way away, adjust the outside linkage rod. With the adjustment right, when you pull on the pto lever, the thrust carrier pushes on the thrust plate and you will see the turnbuckle down the side of the clutch moving. Was it a new or recond clutch? Maybe the lever heights were not set even. It is possible to put the pto plate in back to front. The spline hub goes to the flywheel. I have found some relined plates can be too thick in the linings and will drag.
d masters
04-20-2006 03:34:36
 Re: david brown 1200,pto problem in reply to Baz, 04-20-2006 01:38:53
it was a reconditioned assy,will check out what you mentioned and get back with you.thank you
cact34r
04-19-2006 08:47:56
I'm sure you checked this; but is the linkage for the PTO clutch lever set to the right tension? I had the same tractor and replaced the clutches, but didn't have any problems. It is odd the first time you see the twin clutch/shaft inside a shaft design. Does the PTO clutch lever feel like it is doing anything?
d masters
04-19-2006 11:25:14
 Re: david brown 1200,pto problem in reply to cact34r, 04-19-2006 08:47:56
the lever does not seem to do anything,do not know about lever tension,dad thought we may have got the engine clutch in backwards,but it seems to work fine,could that be?
