hydraulic ram
adeline
04-17-2006 20:31:43
my vai has a large hydraulic ram mounted verticaly on the starter side at mid body of tractor. it is mounted heavily in the body of the tractor what is it designed for?
charley hellickson
04-17-2006 21:21:29
 Re: hydraulic ram in reply to adeline, 04-17-2006 20:31:43
hi. i have a 1950 vai with the same cylinder on it. it has a large rotating pulley on the top. a steel cable is attached on the back side of the cylinder,goes up over the top thru the pulley and down to the mower. it is to lift a side,center mounted cycle bar mower. mine also has a small pulley on the front side at the base. the cable could also be run down and under it and foward to lift something else like a front mounted blade. hope this helps. charley.
Camboted
04-17-2006 20:52:27
I had the same arrangement on a 301. I believe they are for side mount sickle mowers used for highway maintenance.
