46 VAC
olddog
04-17-2006 14:49:25
Has a "knocking" in the driveline while moving. Any gear: slower than engine RPM and a little faster than tire speed. Feels like someone with a 5# hammer rapping on the housing. Any clues?? Been working it pretty hard with a trip FEL and dirt piles. Where should i look first?? Thx in advance for any advice you can offer. RON
1031D
04-17-2006 20:09:49
 Re: 46 VAC in reply to olddog, 04-17-2006 14:49:25
I had that problem in my "54 VAC, turned out to be the torque tube shaft bearings needed to be reshimmed. You can check those bearings out by removing the belt pulley cover or assembly.
Augie
04-18-2006 19:08:53
 Re: 46 VAC in reply to 1031D, 04-17-2006 20:09:49
I'll second that. The torque tube will run dry on a non-eagle hitch VAC long before anything in the tranny.
My VAC puller started that knock summer before last. I went ahead and replaced all of the bearings and seals aft of the flywheel while I had it apart. Ran a little over $500 for parts, but I won't have to ever do it again...
olddog
04-19-2006 05:19:37
 Re: 46 VAC in reply to Augie, 04-18-2006 19:08:53
Thanks for the replies all. Kinda expected probs with this. The tube and trans both had TAR innem' when i got the tractor. was hoping just a drain & flush would suffice. Just got done with a farmalittlest cub, doin' whole back end 15 new seals, 1 brg. Musta done wrong tractor!!!
Walt Davies
04-17-2006 19:45:22
My old Case SI did that it turned out to be a bearing in the tranny. You can check them by pulling the top and then turn it over slowly while looking for movement of gear shaft that are not correct.
Walt
