SC HELP!!!!!!
Rockcricker
04-16-2006 19:23:35
I am need of some help. I have a 48 SC and I got it running had to pull it to start it. Ran real bad. Had the head rebuilt and new rings on pistons. Put back together and ran the same still had to pull it to get it started. I had checked the timing and good spark. I am getting real bummed out. It also smoked out of the breather. Please help.
Walt Davies
04-16-2006 21:12:43
 Re: SC HELP!!!!!! in reply to Rockcricker, 04-16-2006 19:23:35
The smoke could just be that the rings have not seated good yet Or the valve guides are very loose ask the guy who rebuilt the head about that.
I would look into the Carb it sounds like you have a problem there. Take the fuel bowl out of the tank and check for dirt and rust and other junk in the fuel lines. Check where it goes into the fuel bowl where the needle valve shut off is.
Check the float level rebuild the Carb. Make sure that all this is good then proceed with the rest. Also you time this tractor with the opening of the points so get a book on the magneto to check out how to do this. I have a copy I can send if you give your email address.
Walt
Ken in AZ
04-16-2006 20:17:34
Need to ask a few questions first. I assume you checked for water in the oil, oil in the water, and made sure you have good fuel flow and air flow.
Does it run better or different with the choke? Does it run better at idle or does it die?
Did you set the valve clearances?
Do you know which cylinders are weak or not firing?
Do you have an intake manifold leak?
How good is your spark? Do you have it to each of the plugs?
When I have something like this, start with the basics. If you have it running and it sounds like a steady misfire, I will take my jumper cables and start shorting plug wires one at a time until I figure out which cylinder(s) might be bad. Then I can start swapping parts around (plugs, wires) and see if that helps. If I suspect an intake manifold leak I have a propane torch I will use to find it by turning the torch on slightly (without flame) and it should start running better when I get near the leak with the propane.
A compression check might tell you if you have a valve that's not opening or closing. I've had a D that seems to have trouble with a valve sticking if it's sat for 6 months or more... once in a while one of them will stick and I have to pull the valve cover, oil everything down, pull the pushrod out, tap it flat on a vice or anvil, put it back in, adjust everything and spin it over... it fires up and purrs great.
When you crank it, does it sound like each cylinder has compression or is there one or two that seem soft or hiss when you crank it over?
Tell us what it's doing or not doing at we might be able to help a little better.
These engines should be pretty simple but sometimes you need to interpret what they are trying to tell you.
Ken in AZ
Rockcricker
04-16-2006 20:43:52
 Re: SC HELP!!!!!! in reply to Ken in AZ, 04-16-2006 20:17:34
Not sure how to ck air flow. Dies at idle or if I choke it. Did ck and reck valve clearance. All cylinders are firing. At least they are all hot. Don't think I have a leak but will try to ck. I have new spark plugs and wires. I will reck the spark on all of them. The head was just rebuilt and new rings on the pistons. Thanks for you help.
Ken in AZ
04-16-2006 21:17:12
 Re: SC HELP!!!!!! in reply to Rockcricker, 04-16-2006 20:43:52
Hmm... if it dies at idle or if you choke it, you might have a carburetion issue. Probably not an intake leak since it sounds like it"s running rich. since choking it makes things worse.
My first thought is: does it sound like all cylinders are firing? Or does it sound like one of those Green tractors with a repeatable, uneven sound? I"ve been fooled by checking temperature to see if they"ve been firing but don"t know how you"re checking temperature on them (finger against the plug base comes to mind).
My next thought is whether the float is sticking... if it dies, does fuel run out of the carb? Are the plugs getting black or wet? These are indications of excess fuel (rich). You might also have the carb jets set wrong; have you adjusted those? Has the carb been apart anytime recently? Sometimes a good cleaning will do wonders.
Another one that can get you is a cracked fuel float. If you take the carb apart, check to see if the float has fuel in it... it will slosh if you shake it and there"s fuel in it. While I"ve been successful soldering them up, it"s really not worth the trouble; just buy a new one and get rid of the troubles.
Also, you could have an ignition issue that makes it feel like a carb issue. You mentioned setting the timing though so that shouldn"t be it but it"s worth rechecking. The spark should be blue, not orange, and I generally use an old plug to check this. Orange usually means you"re going to say a lot of bad things to get it started.
the smoke out the breather is probably because you have new rings and it might take a bit to get them seated so I wouldn"t worry about that just yet.
Hope this helps.
Ken in AZ
