dctom, Don L, F.I.T, any one else that's worked on
DCPULLER
04-16-2006 06:35:58
Gentlemen, I need your wisdom. I'm refering to the questions I posted earlier, VAC governor running wild help! Dave S
vac400
04-16-2006 09:29:56
 Re: dctom, Don L, F.I.T, any one else that's worke in reply to DCPULLER, 04-16-2006 06:35:58
DC Puller
I have my dads VAC and it had the same problem a long time ago.Remove the timing cover and you will must likely fine the cap has come off of the stem. Also check the rest of the weights. Jerry
DCPULLER
04-16-2006 09:35:47
 Re: dctom, Don L, F.I.T, any one else that's worke in reply to vac400, 04-16-2006 09:29:56
Jerry, I was told there is supposed to be a spring in there someplace also. Ever see where that goes? I know there was none when I took it apart. Dave S
Walt Davies
04-16-2006 10:38:50
 Re: dctom, Don L, F.I.T, any one else that's worke in reply to DCPULLER, 04-16-2006 09:35:47
there is no spring in the governor there is a spring on the linkage from the governor to the throttle lever. The throttle lever pulls on this spring to set the speed of the engine the governor pulls against the spring to shut the engine back down to idle. Its the two opposing forces that set the speed of the engine.
