2670 dampener pully
What happened n
04-15-2006 15:29:47
The dampener pully worked loose on the crank. The half moon key way is hurt and the pully is hurt. The right way to fix this would be to put a diffrent crank and pully in. I'am open for other suggestions. I hope there are some. Thanks in advance. Ralph
dwag
04-15-2006 18:32:38
 Re: 2670 dampener pully in reply to What happened now, 04-15-2006 15:29:47
A mach shop can put a keyway on opposite side if O.D. of crank is not worn down. After that, just do your timing on #6 instead of #1. A shop in Ceder Rapids Ia. (Horn Automotive) said they could build up\ weld cranks with this problem.
Eagle Doc
04-16-2006 19:03:02
 Re: 2670 dampener pully in reply to dwag, 04-15-2006 18:32:38
With the key way on the opposite side of the pulley you could not use the existing timing marks because both cylinders (one and six) would be at the bottom of the stroke instead of at the top.
dwag
04-18-2006 10:34:49
 Re: 2670 dampener pully in reply to Eagle Doc, 04-16-2006 19:03:02
Good Point! I was wrong. Don"t know where I came up with that line of B.S. dwag
