Case 2470 power shift, no 2nd or 3rd
Mike S 806/H
04-15-2006 14:30:35
Im looking at a 2470 but the 2nd and 3rd dont work,it does nothing in 2 or 3rd, 1st works good, he told me it was fixed about 15 years ago and it worked good then, they havent really used it for 13 years now, any ideas on what could be wrong? and how much $$$ to fix it? I will do all the repairs myself.
dwag
04-15-2006 18:40:17
 Re: Case 2470 power shift, no 2nd or 3rd in reply to Mike S 806/H, 04-15-2006 14:30:35
Tractor probably has weak\no Hyd"s in 2nd or 3rd. The 6 bolts that hold c2,c3 clutch hubs together are broken. When fixing, make sure the c2,c3 piston carrier is splined, if not replace it. Also the 6 3\8 bolts can be upgraded by machining hub to accomadate 7\16 bolts. Not a big job$
Mike S 806/H
04-16-2006 09:06:08
 Re: Case 2470 power shift, no 2nd or 3rd in reply to dwag, 04-15-2006 18:40:17
Thanks for the info dwag, Do you think it would be ok to drive this tractor home about 5 miles?
dwag
04-16-2006 19:13:51
 Re: Case 2470 power shift, no 2nd or 3rd in reply to Mike S 806/H, 04-16-2006 09:06:08
Your call, stay in 1st range. If tractor were mine, I"d drive it home.
