VAC block
Nedd
04-14-2006 13:20:56
I remember reading a while back that there is not much difference between the 148 block and the VAC block. I have a 148 that put a rod through the side and was wondering if a vac block would work? Would some machining be required? Would 148 crank fit in VAC block? just wondering if anyone has tried this.
fran400puller
04-14-2006 15:31:13
 Re: VAC block in reply to Nedd, 04-14-2006 13:20:56
148 crank will not fit in vac block,though all of the other parts will.i have a 148 block in my vac only had to mill .5" oof of flywheel for clearnce.if going the other way you should be fine.make sure to use vac flywheel.will also need to adjust clutch fingers.goodluck;fran
fran400puller
04-14-2006 15:30:52
