calcium cloride
Dale L
04-13-2006 15:54:48
I'm draining calcium chloride out of my tractor rear tires and I will probably have about sixty gallons when I am done draining. How do I dispose of all the old calcium chloride? Thanks,
Dale
Dale L
04-15-2006 12:30:18
 Re: calcium cloride in reply to Dale L , 04-13-2006 15:54:48
I guess I'll just put it on the driveway!
Paul f
04-14-2006 10:06:20
Our township uses it for dust control on our dirt roads
630crazy
04-14-2006 07:32:13
It does not evaporate either, so if you have a puddle somewhere it won't go away until it soaks into the ground or rain washes it away.
jahaze
04-14-2006 05:48:21
Dale,
The one thing you need to watch is if you dump it on the ground make sure you do it somewhere you don"t plan on having anything grow for a long time (like a gravel driveway), salt has a way of preventing things from growing.
Joe
Roger300
04-13-2006 19:06:46
Dale; Calcium chloride is just salt added to the water to increase the weight and isn't harmful,
I usually, if I'm not going to put it back in the tire,just let it run out on the gravel around the shop.When I was still farming I would put it back in the tire, would increase traction. Roger
