Case 830 LP
C McKellips
04-13-2006 06:18:11
I don't think I was clear on my previos post so I will try again. My Case 830 LP sat for 10 years. The question is: Will it run off of a small propane bottle from a bar b que grill? The bottle has a new style valve in it. If any body knows the answer to this I would appreciate your help. All we want at this time is to hear the tractor run. Thanks.
Engineer20
04-13-2006 06:50:25
 Re: Case 830 LP in reply to C McKellips, 04-13-2006 06:18:11
Yes, your tractor will run on the BBQ bottle. You'll have to have the proper connections, and hooked up at the right spot. You might have to have your local LPG man set you up with the right connections. I have seen a Case LA run on a BBQ bottle, but can't remember how he had it hooked up.
