Elmer or Barry - DB 780 -Jumpy Lift
TDK
04-12-2006 09:55:29
Just replaced hyd. valve, spool valve was sticking. Reset everything according to factory manual.Bled system according to manual except for the connector plate which the 780 apparently does not have. Where this plate is on a 880/990 this tractor has an aux. valve. Does this valve need to be bled also? Now when lifting, with or without load, lift jumps or pulsates. One other problem, it will switch to TCU & Height but will not switch to Depth ! Is these two problems related ? Everything else seems ok. please tell me what is wrong. did I make a mistake or what ?
Baz
04-13-2006 03:13:28
 Re: Elmer or Barry - DB 780 -Jumpy Lift in reply to TDK, 04-12-2006 09:55:29
Sounds like oil problem. Are you sure the filter is clean, pump could be starving of oil. Does your tractor have the vacuum switch under the pto housing, I have had these suck air through them. Put switch into TCU, pull lever hard back, is this the same? Tcu works directly on the spool unlike Height/Depth. Remove by-pass valve, turn engine over on starter to flush port, clean restrictor washer [alloy] inside valve.
TDK
04-13-2006 21:48:23
 Re: Elmer or Barry - DB 780 -Jumpy Lift in reply to Baz, 04-13-2006 03:13:28
Have flushed by-pass valve. Why can't I get the switch into TCU ? It does have the switch under the differential between the drawbar, is this it ? Don't see any wires or hoses attached to it though. Can the switch suck air & not lose any fluid from it. Lift holds, but now is starting to jump while sitting still, as well as when raising. Acts like it very slowly looses height & then raises slightly.
Elmer
04-12-2006 17:58:08
Does the hitch hold a load when the tractor is shut off?
TDK
04-12-2006 18:48:58
 Re: Elmer or Barry - DB 780 -Jumpy Lift in reply to Elmer, 04-12-2006 17:58:08
Yes, it holds a load fine ! I'm starting to panic, need it fixed. Thanks.
