cylinder kit installation
mike richmond
04-12-2006 09:04:22
I am inquiring on how hard it is to install cylinder kits in a 580c backhoe 208 engine. is there any special trick to remove the sleeves?
Walt Davies
04-12-2006 09:37:38
 Re: cylinder kit installation in reply to mike richmond, 04-12-2006 09:04:22
Are they wet or dry sleeves I have never replaced them on this tractor but have on many Cats with wet sleeves.
If they are wet then they should just knock out from the bottom You need to have a metal piece made to push them out with. It should have a rim that fits inside the cylinder with a small lip to push against the outer ring of the cylinder. It should be about 3/4 of an inch thick. You can make it on a lathe its not hard.
Now use this to push the cylinder out I used a sledge you can use a hydraulic jack also. they should come out pretty easy. a little heat around the bottom to break the oil ring loose can help also.
Dry Ice will help but you should not need that.
To install make sure that the block is clean, clean, clean and no burrs or bad spots that will catch an O-ring. Clean the cylinder off of all preseritive oils and then use engine oil to coat them liberally don't be shy it won't hurt to have more than you need but too little will ruin an O-ring. Just push them in by hand they should go in easy. You can tap them in the last little bit with the tool that you made to remove them with.
Email me and I can show you a drawing of what the tool should look like.
Walt Remember patiance is a virtue.
mike richmond
04-12-2006 10:25:47
 Re: cylinder kit installation in reply to Walt Davies, 04-12-2006 09:37:38
I am not sure if the sleeves are wet or dry, I have never done a case before either. I am attempting to do this in frame, to keep from pulling the engine. Thanks Mike
Roger (Mi)
04-14-2006 04:13:47
 Re: A 580C will have wet sleeves in reply to mike richmond, 04-12-2006 10:25:47
Yes, sleeves can be installed in-frame. Sometimes sleeve pullers can be rented, though they're not difficult to make. Use 5/8" ready rod for the screw to pull the sleeves. Let a machine shop make the piece to pull the sleeves from the bottom. You don't want to mar the block as the sleeves are pulled, otherwise you'll have anti-freeze in your crankcase oil. Good luck.
