Treespade on a Case
Skyhawk Greg
04-12-2006 08:27:19
Hello, Over the weekend, I found a good deal on a 32" tree spade. I don't own a skidsteer, so I have to mount it on one of my tractors. Of my four tractors, only two stand any chance of fulfilling the bill. One is a 1988 2120 Ford with a 12 x 12 transmission. The second one is a 1968 Case 580CK backhoe. If using the Ford, I would mount the spade using the three point hitch system. If using the Case, I would probably remove the loader bucket and replace it with the spade. It would be simpler to use the Ford, but am not sure it could handle the spade weight of 1500 pounds, and ball weight of 400 more pounds. On paper, the Case looks like it will work. Any thoughts or past experiences would be appreciated. Thank you, Greg
Skyhawk Greg
04-14-2006 06:50:00
 Re: Treespade on a Case in reply to Skyhawk Greg, 04-12-2006 08:27:19
With this idea in mind, would anybody have an old front loader bucket that would fit a 580CK? It could be in very poor condition because all I would need is the pivot section in the back of the bucket that connects the bucket to the loader arms. This could be cut out with a torch and welded to a plate and adapted to the tree spade. Thank you. Greg
Skyhawk Greg
04-13-2006 07:57:24
Thank you George!
george md
04-12-2006 09:18:24
Greg, I mounted one on an old MM tractor with loader and backhoe, it worked quite well , when he needed the extra weight to push the spades in the ground he would set the hoe on the ground for balance . 580 CK is much more tractor than the MM is .
george
Skyhawk Greg
04-12-2006 10:03:34
 Re: Treespade on a Case in reply to george md, 04-12-2006 09:18:24
George,
Did you mount the spade onto the front of the loader bucket, or did you remove the loader bucket, and then mount the spade to the loader arms? I have thought about both methods. If mounted to the loader bucket, some sort of quick attach device could be welded together that would allow the operator to drive up to the spade, pick it up, then lock it into place. Removing the loader bucket would take longer, but the effective load on the loader arms would be reduced by a lot. There are advantages either way. Thank you, Greg
Skyhawk Greg
04-12-2006 10:03:02
George,
george md
04-12-2006 11:12:49
 Re: Treespade on a Case in reply to Skyhawk Greg, 04-12-2006 10:03:02
Greg,
We took the bucket off , object is to get the spade as close to the tractor as possible . And also he was never going to use the tractor as a backhoe anyway , he has a 580 B backhoe to dig with .
george
