800 head cracks
INCase
04-11-2006 09:02:42
pulled the plugs last night to see what they looked like. looked inside the cylinder (#1) thru the plug hole and noticed a drop of anti-freeze hanging from the inside of the head. pulled the #2 plug and there were a couple drops of antifreeze hanging from the exhaust valve (open). #3 and 4 "looked" ok, no antifreeze seen. I got about 1/2 cup of antifreeze out of the oil pan. I'm guessing the head is messed up in both cylinders. Has anyone had luck getting these fixed? This head had been replaced before. It did not have the eagle or the 6530A #. it only has JIC roughly cast in where the Partnumber goes. thanks for the help
INCase
04-13-2006 08:09:59
 Re: 800 head cracks in reply to INCase, 04-11-2006 09:02:42
I presume that a leaking head can get water into the oil pan. If not another question would be, does water in the oil indicate anything else? thanks.
