Case carb.
Levi Bratt
04-10-2006 19:51:08
I have a 1949 Case model S I need to put a good working carbeurator n it in order to get it up and going again. ould some one tell me if there are are other carbs out there that will fit my tractor besides the Zenith and if so where I may find one.
Walt Davies
04-10-2006 19:58:02
 Re: Case carb. in reply to Levi Bratt, 04-10-2006 19:51:08
Actually that old Zenith is an very good Carb. I would get a kit to overhaul it and then go to the dealer thye can still get you a new float get one I did on mine and it made all the differance in running. The old floats will get some fluid in them and won't work and fixing then just ain't worth the effort.
Walt PS you can get agood kit from e-bay, JOhn Salie or the dealer.
Levi Bratt
04-14-2006 06:51:36
 Re: Case carb. in reply to Walt Davies, 04-10-2006 19:58:02
I would get a kit to rebuild the carb if i had the carb but since it was much worse than just the float and in need of a rebuild kit i decided to scrap it. there was only one ear left for the mounting bolts and every screw on it was seized in place. So I am wondering if there are other sources for a carb that will work besides other model s or similar sized case tractors, or if anyone knows if any of the other tractor manufacturers had a carb that will fit on my tratcor.
