identify 430
james363
04-10-2006 13:54:59
i purchased case 430h was told it was 1970 how do i tell if its ag or ck or triple range, it is a deasel. i want to buy a manuel but want to make sure i get the right one, do the years differ alot.
John Nonmae
04-10-2006 18:43:59
 Re: identify 430 in reply to james363, 04-10-2006 13:54:59
The 430 production ended in 1969. The 70 series started in 1969. Need a little more information about your tractor. Could be a utility version with the heavier front-end and shuttle transmission. If its triple range it should have 2 levers, H, D, L. Please post a little more info. Thanks.
james363
04-11-2006 08:56:05
 Re: identify 430 in reply to John Nonmae, 04-10-2006 18:43:59
it has 1 lever to the left forward and reverse one to the right that might be the h d l, foot clutch to the left both brakes and foot throttle to the right hand throttle to the left.
John Noname
04-11-2006 14:11:44
 Re: identify 430 in reply to james363, 04-11-2006 08:56:05
If it has the shuttle transmissionit should be the utility version. On the rowcrop versions the other lever would work with the "live" power.
