What lube to use?
Will in Winter
04-10-2006 11:37:42
I have a 420 diesel Industrial model with a Bosch gravity fed injector pump and govenor setup. The plate on the side says to change the lube at each oil change. What would be the proper lubricant to refill them with?
Thank you
rongrong
04-10-2006 19:43:48
 Re: What lube to use? in reply to Will in Winter Garden, 04-10-2006 11:37:42
just put in the same oil as you use in the engine
