case 430 problem
james363
04-10-2006 08:51:31
just bought case 430 not sure year late 60 or early 70, starts runs good but when i put it in gear does not move like clutch is still in, any ideas whats wrong.
Paul in ON
04-10-2006 09:10:07
 Re: case 430 problem in reply to james363, 04-10-2006 08:51:31
Make sure that your hand clutch is up/engaged. It's the 2 foot lever on the left side just in front of your knee.
james363
04-10-2006 10:23:08
 Re: case 430 problem in reply to Paul in ON, 04-10-2006 09:10:07
is that the forward and reverse if so it is engaged
Paul in On
04-10-2006 15:22:03
 Re: case 430 problem in reply to james363, 04-10-2006 10:23:08
No, it's just another mid mount clutch. What case used for their live PTO. You can let the clutch out, with the hand clutch disengaged and the PTO will do. Then Pull up on the hand clutch all the way, and that will get the tractor moving. MAke sure the hand clutch is pul;led up and doesn't flop around. Paul.
JAMES363
04-10-2006 16:00:08
 Re: case 430 problem in reply to Paul in On, 04-10-2006 15:22:03
thanks
JMChapman
04-10-2006 12:12:02
If it is like my 530ck there are two levers that can slip out. On the left by the clutch is the forward/revers selector. On the right side there is a low/high range selector that also can be warn a little and it will slip out. Also make sure there isn't anything blocking the clutch linkage itself. Hope this helps!
james363
04-10-2006 13:18:31
 Re: case 430 problem in reply to JMChapman, 04-10-2006 12:12:02
i tried the foward reverse and the high low i will look for anything blocking the clutch, thanks for your help, any other suggestions
Bob KY
04-11-2006 06:17:17
 Re: case 430 problem in reply to james363, 04-10-2006 13:18:31
If its a Case o matic, you might just be low on fluid. The case o matic clutch pedal is connected to a valve on top of the bell housing- also you would have a clutch pressure gauge on the left side of the steering wheel.
