CAse 430 Adjustable Wide Front
Paul L
04-09-2006 19:29:31
Is the wide front usually set as close together as possible? Any bonus to operating a loader with the wheels extended wider?
Walt Davies
04-09-2006 21:35:23
 Re: CAse 430 Adjustable Wide Front in reply to Paul L, 04-09-2006 19:29:31
The front wheels should just inside the outer edge of the bucket enough so that you can make small turns without ruining a tire. the rears should be about even. The bucket should the widest point on the tractor.
Walt
Tom (Ks)
04-09-2006 20:27:36
Most people set the axle width to the row spacing they are using (30", 36", etc.). If you install a loader, the loader manual should give the minimum width you should use. That should be around 76" for some loaders. I have mine set all the way in for rear blade work.
