broken pin in shifter mechanism 2290
harborside
04-09-2006 13:58:18
I have a broken pin inside the transmission housing that operates the 1-2 linkage. Just inside the housing on the stub shaft that goes through the housing. I can't see any way to r+r this pin. I tried looking inside with a mirror but can't seem to get a good angle to remove it. I can't remove the snap ring just inside the housing either. Does anyone have any tricks to replace this?
dwag
04-11-2006 10:21:25
 Re: broken pin in shifter mechanism 2290 in reply to harborside, 04-09-2006 13:58:18
Remove shift cover, detent balls and springs in forks, seperate shift rail by removing roll pin through opening in park detent, move rail halves to remove fork assembly"s/rails from housing. Remove outside shift lever and 1/2 moon key and withdraw shaft and holder from inside. A Case shop manual would be a big help.
