530 Case
Fahmah
04-09-2006 06:44:30
After changing the ground to positve and making sure I polerized the VR it still doesn't seem to be charging?
Phil (NJ.AZ,Sask)
04-09-2006 07:57:16
 Re: 530 Case in reply to Fahmah, 04-09-2006 06:44:30
Are you sure the VR is correct for that GEN. There are two types of VR's, one supplies a Ground to GEN Field (A Type) and the other supplies Voltage (B Type). The Type of VR must match the type of GEN.
The best way to polarize is to "motor" the GEN. (Loosen the fan Belt and see if the gen motors when you Jumper (Polarize) the Field).
I have a 530ck that is Neg Ground (12V) and the
ground bolt (mounting of VR)loosens up causing problems.
Hope this Helps,
