jumpy hydraulics on 1210 David Brown
Mitch Furness
04-09-2006 03:11:42
I have replaced orings in releif valve under gearbox. This stopped a bad oil leak but now the hoist jumps 2-3 times before it gets to the top of its lift. Does hydraulic system need bleeding or there something else happening. It worked perfectly before this. It also seems to be intermittent, less ovious when hot. What sort of manual would help dianose this and if it is in need of bleeding how to bleed it? Thanks for help.
Walt Davies
04-09-2006 11:54:07
 Re: jumpy hydraulics on 1210 David Brown in reply to Mitch Furness, 04-09-2006 03:11:42
Mitch, The system should be fully self bleeding, I woul go back to the valve that you worked on and look for something hanging up in it. A bad "O" ring or a rough spot or burr.
Walt
Mitch Furness
04-09-2006 13:29:27
 Re: jumpy hydraulics on 1210 David Brown in reply to Walt Davies, 04-09-2006 11:54:07
Thanks for reply Walt. The leak was very bad so was hoping not to have to go back there but might just have to do that. Regards Mitch
