Ground for a 530 ?
Fahmah
04-08-2006 07:54:18
I have a 1963 530 case. I had work done to the genorator and replaced the voltage reg but it still doesn't seem to be charging? Is it possible this should be positive ground as opposed to negative ground?
Mike in MI
04-08-2006 15:59:13
 Re: Ground for a 530 ? in reply to Gene Dotson, 04-08-2006 14:36:26
Thanks guys for your information! Now I know mine"s right. Gene, That is a good easy way to remember.
Thanks again!
Mike
Tom (Ks)
04-08-2006 09:48:33
 Re: Ground for a 530 ? in reply to Fahmah, 04-08-2006 07:54:18
Positive ground was used on gas tractors before serial number 8233766 or sn 8232882 diesels. If yours is a 1963, then it should be positive ground.
Mike in MI
04-08-2006 12:24:22
 Re: Ground for a 530 ? in reply to Tom (Ks), 04-08-2006 09:48:33
Tom,
This is a good question that"s been asked here!
I"m courious now what way it should be also?
I have a 1966 Case 530 gas SN# 8281361. If I remember correctly it has negative Grd. This has generator setup W/Voltage regulator With idiot light instead of a gauge setup.
Was just woundering cause I have now Opperators manual to look this up with only a parts book.
Mike
Tom (Ks)
04-08-2006 14:03:46
 Re: Ground for a 530 ? in reply to Mike in MI, 04-08-2006 12:24:22
If my books are correct, sometime in 1964 they changed to neg. ground. I looked at a 1964 430 about two years ago, but I did not look at the battery setup on it.
