Eagle hitch tractors
How much space
04-07-2006 19:45:22
Is the space between the eagle hitch arms the same distance on early 300 and 400 tractors (not the B series)?
Also, is the space the same on a 630 with cat.1 eagle hitch the same as a 630 with cat. 2 eagle hitch?
How much space
04-08-2006 19:21:20
 Re: Eagle hitch tractors in reply to How much space, 04-07-2006 19:45:22
Thanks to all of you who took the time to respond.
How much space
04-08-2006 09:56:38
The reason I asked the second question was because I had a busted jaw, (the part that slides) on my 630 eagle hitch. I aquired another from a parts 630 tractor and after I put it in, I noticed the jaw was much bigger than the original and so I presumed it was for a cat. two hitch, but I wasn't sure Case offered cat two on an eagle hitch 630. If not, should I presume the parts tractor had parts off an 800 or early 830?
John Saeli
04-08-2006 10:00:01
 Re: Eagle hitch tractors in reply to How much space, 04-08-2006 09:56:38
The only E-H that was Cat 2 was the 830. We stock E-H parts.
charley hellickson
04-07-2006 21:17:09
hi. there was no cat. 2 eagle hitch. all eagle hitches were the same size and the same spacing. eagle hitch draft pins are slightly larger diamenter than cat.1 3pt. i found this out when i went to put a cat. 1 to cat. 2 adopter bushing on my eagle hitch plow,it didn't fit on the draft pin. and all 3pt equipment does not fit eagle hitch,some of the hitch spacing is to wide. cat.1 draft pins will fit but cat2 is to big. hope this helps. charley.
John Saeli
04-08-2006 17:49:21
 Re: Eagle hitch tractors in reply to charley hellickson, 04-07-2006 21:17:09
Hey Charlie: Just got your card today. Thank you very much. Appreciate the kindness very much.
charley hellickson
04-08-2006 22:56:10
 Re: Eagle hitch tractors in reply to John Saeli, 04-08-2006 17:49:21
Hi John. Your welcome very much. That mail made good time,it didn't leave town till 5:00 P.M. Wednesday and then goes to Des Moines. Thanks I learned some more,I didn't know about the 830 CAT 2 hitch. They must have decided the 830 was getting enough power it needed bigger pins. All the latches must interchange. I know one thing that dosn't swap and that is the center links. the 300 is different the way it mounts on the tractor,it has to have a different tractor end. Charley.
John Saeli
04-09-2006 08:45:43
 Re: Eagle hitch tractors in reply to charley hellickson, 04-08-2006 22:56:10
Hey Charlie: Some time back, a customer gave me the Part # for the Cat 2 Latches. Now, I can't find it. The Parts Book doesn't list them. ?????
John Saeli
04-08-2006 05:39:19
Hey Charlie: The Latchs on the 830's were opened to Cat 2.
DKase
04-08-2006 10:11:14
 Re: Eagle hitch tractors in reply to John Saeli, 04-08-2006 05:39:19
Not on any 830 that I ever had. They were all exactly the same as the DC. DK
