SC Steering Play
Glenn FitzGeral
04-07-2006 09:43:25
Have any of you successfully taken the steering play out of the gearbox of an SC? I am very happy with my little SC but a little less play in the steering would be nice. Last summer I had the top off the transmission and concluded it was just wear in the gears. I already turned it 180*. Glenn
John Saeli
04-07-2006 19:31:46
 Re: SC Steering Play in reply to Glenn FitzGerald, 04-07-2006 09:43:25
Hey Glenn: Did you try adjusting the play out?
Camboted
04-07-2006 20:13:57
 Re: SC Steering Play in reply to John Saeli, 04-07-2006 19:31:46
Glenn,
We had that trouble in some DC's and you just have to add shims under the steering column until the play disappears. I'm not sure that the SC is the same but suspect it might be. That plus the end play adustment on the side of the steering bos with good ball joints should make her tight as new. I doubt if you worm is worn, especially since you turned it. One way to check is this: When you turn does your steering wheel shaft move up and down? If so that is your problem.
Glenn F.
04-08-2006 21:50:03
 Re: SC Steering Play in reply to Camboted, 04-07-2006 20:13:57
How does one access those shims? Do you take the top off the transmission? Glenn F.
John Saeli
04-08-2006 05:41:09
Hey Ted: If the shaft moves up & down, that's an indication the Bearings down @ the bottom are shot.
Camboted
04-08-2006 07:55:37
 Re: SC Steering Play in reply to John Saeli, 04-08-2006 05:41:09
True, they are the first place to look, but even new bearings don't always solve the problem. That's why Case put all those shims under the steering column
