Sight for sore eyes
Erik OK
04-06-2006 19:50:01
third party image
These stubborn things finally let go with a little coaxing from the 12 ton bottle jack, home-made sleeve puller, and packed them with dry ice.
D boll
04-07-2006 10:31:40
 Re: Sight for sore eyes in reply to Erik OK, 04-06-2006 19:50:01
The other point on allthread is to get the black stuff, any with a military spec is usually good, the silver stuff is soft, I have seen one inch stuff break and launch stuff into the air until a 15 foot ceiling stopped it! Buy the grade 5 or 8. Or a kevlar suit!
RobertTX
04-07-2006 05:26:41
I get them out by torquing the all thread all it ca stand, then rapping the side of the block with a hammer. Have pulled many that way.
Ken in AZ
04-07-2006 06:45:13
 Re: Sight for sore eyes in reply to RobertTX, 04-07-2006 05:26:41
On mine I ended up stripping out the allthread a couple times. I rapped on the block as much as I dared when tight too.
Finally I used 2 pieces of 3/4" fine thread allthread thru a square tube beam with a hydraulic jack under each side of the beam. When the allthread was fully stressed (tapping on both to make sure they were both tight) I had to heat the block with a big propane torch (I tried tapping all over the block too) and then they FINALLY gave up.
Since it was my first time taking out sleeves, maybe mine was a bit more difficult than normal? Or I just did something wrong? At any rate, they all came out undamaged so I can reuse them.
Ken in AZ
Ken in AZ
04-06-2006 22:53:44
Wow! If that's a D block, that dry ice must have been very helpful or they wanted to come out a lot more than mine did. I'm with Walt on the chain part; I was stressing the jacks pretty hard and if I had used any chains I have, it WOULD have broke the chain; it stressed both pieces of 3/4" all-thread that I used.
good job!
Ken in AZ
Erik OK
04-06-2006 19:52:00
third party image
Here is a pic of the process.
Walt Davies
04-06-2006 22:37:40
 Re: Sight for sore eyes in reply to Erik OK, 04-06-2006 19:52:00
Boy! I sure wouldn't trust that small chain with a 12 ton jack. You are lucky it didn't break and let you have it right between the eyeballs. Chains are not made to hold that kind of pressure. Walt
