2870 Rear Axle Pinion assembly
Kendal Flynn
04-05-2006 20:35:43
How hard is it to replace the rear Pinion Bears? Do you have to pull a part the hole Dif? If anyone has time could they send me info out of the service manual.
c hess
04-06-2006 18:19:11
 Re: 2870 Rear Axle Pinion assembly in reply to Kendal Flynn, 04-05-2006 20:35:43
Not a expert on this but looks like a big job. You need to remove wheels- planitaries an trunion from axles- than you can pull axle than you remove differential in center. Trunion is part that is on end of axle an has couple bolts holding it on. No need to take steering u joints apart . There are about 8-10 large bolts to remove to take trunion off. Must do both sides. Thats what 4490 manual says.
