How did Case De-Tune the VA Engine?
C. Amick
04-05-2006 09:48:20
I've read that Clausen the CEO of Case ordered the "VA" series tractors de-tuned so that they would have significantly less horsepower than the "S" series tractors. Did they do it by adjusting the valve timing?
JR(CASE38MAN)
04-05-2006 11:51:29
 Re: How did Case De-Tune the VA Engine? in reply to C. Amick, 04-05-2006 09:48:20
It was the V series.He made them cut the r.p.m. back on them.that engine if turning 1800 rpm will produce 32 hp..according to other tractors that used it..
Alberta Mike
04-05-2006 10:43:34
That was the V series, not the VA series. I've read that myself in probably the same book that you are referring to. It could be done by lowering the compression ratio but that would require a major engine modification which Classen would probably not go for since he was such a skinflint. Other easier ways would be to retard the ignition spark or lowering the maximum RPM via the governor setting.
mj
04-05-2006 11:40:55
 Re: How did Case De-Tune the VA Engine? in reply to Alberta Mike, 04-05-2006 10:43:34
I recently read somewhere, maybe on this forum, that the plan was for 168 cu.in. and a 6-speed transmission when the VA series was in the design stage BUT Clausen dictated the 124 cu.in. engine coupled to a 4-speed to protect the 'S' models' market share. Too bad, that would have been a legendary tractor!
