Question about a 210bh
scottinwv
04-05-2006 05:08:51
Does anyone know if the backhoe had its own resevoir or did it use the tractors belly? Thanks scott
TimBinWV
04-08-2006 05:45:48
 Re: Question about a 210bh in reply to scottinwv, 04-05-2006 05:08:51
What part of the state you in,Scott?
freespirit
04-05-2006 09:40:29
Yes, the Backhoe on the Case 210BH has its own reservoir!
scottinwv
04-05-2006 13:08:12
 Re: Question about a 210bh in reply to freespirit, 04-05-2006 09:40:29
Thanks for the reply. Do you happen to know what the capacity of it was and where it was located on the hoe. Was it integral or a seperate tank. My 210 had the hoe removed before I got it. Am now installing a ferguson 220 hoe on the tractor. Still have the original case backhoe pump on the rear of the tractor and need to figure in a reservoir for it i guess. Thanks Scott!
freespirit
04-05-2006 16:36:41
 Re: Question about a 210bh in reply to scottinwv, 04-05-2006 13:08:12
Tank is located at rear of tractor where your hydro pump is that comes off the PTO shaft. It is actually attached to the backhoe part right below the hoe control arms are located. Size of tank uses approx. 13 US qts..Tank cap is pressurized to 15 lbs.. We have the owners manual for the 21 backhoe that came with our 1959 Case 210BH tractor! If you need pics of pages from this feel free to let us know! Might contact your Case dealer for other info!
scottinwv
04-05-2006 20:05:57
 Re: Question about a 210bh in reply to freespirit, 04-05-2006 16:36:41
Thanks again. Would you have pictures of the hoe mounting brackets/frame on the hoe and the tractor? I still have the 2 brackets on the axle housing and the 2 arms from the loader frame going back to the hoe and was wondering what the original setup looked like. Trying to get an idea of how to adapt to the ferguson hoe as it also had a similiar 4 pt mount setup. I want to be able to disconnect fairly easily. If you do you can send to my email or post here. Would greatly appreciate it. Thanks Scott!
freespirit
04-06-2006 08:02:07
 Re: Question about a 210bh in reply to scottinwv, 04-05-2006 20:05:57
I can send you pics from the operators manual or some of our tractor! If I send from the manual then it won't be until tomorrow. Will do the best I can to help you! We are in Texas so time may be different. Send me your email address! I think these people here will give it to you!!
