Need Help On CASE 530CK
William C. Guld
04-04-2006 12:45:41
I am restoring a 1969 530CK and must replace 3rd & 4th gear in the transmission. I am having trouble removeing the rear oil seal housing from the main shaft.The tractor does not have PTO and there is a plug inside the housing P/N G10338.It would really help to know if this housing is just pressed on the main shaft,might there be a nut or snap ring behind the "plug" or some other method of holding it on. Any help would be greatly appreciated. Thanks, Bill G.
Phil (NJ, AZ,SaSK)
04-08-2006 00:15:08
 Re: Need Help On CASE 530CK in reply to William C. Gulden, 04-04-2006 12:45:41
Bill, My book just says to use a suitable puller...
page 66-18 removal & reassembly. It does have some babble about the Oiler cup (non-PTO) but that is on the opposite end of the shaft.
Hope this Helps,
