Poping back thur carb ????
Mark from Iowa
04-03-2006 16:50:07
I have a AC-B- with a belly mower...don't use much...got it out tonite and now and then it pops back thur the carb...Question...is this a dirty carb ?? or what ?? THANKS for any advice I get....I have more Case than AC...THEY are the... OTHER...COLOR... THANKS..again...MV
C. Amick
04-04-2006 09:44:49
 Re: Poping back thur carb ???? in reply to Mark from Iowa, 04-03-2006 16:50:07
If none of the suggestions below work, you might try changing out the condenser.
Gene Dotson
04-03-2006 19:06:10
My first suspicion would be an intake valve that is sticking. This is common with tractors that sit arond a lot. Get some good upper cylinder and valve additive and add some to the oil and some to the fuel... Gene
dctom
04-03-2006 17:07:01
advance the timeing a little, should help it or reset point and plug gap slow timeing will cause that tom
Mark from Iowa
04-03-2006 19:03:53
 Re: Poping back thur carb ???? in reply to dctom, 04-03-2006 17:07:01
THANKS...I will try that tomorrow
