C Rearend noise
Mike Shultz
04-03-2006 13:49:05
I bought a Case C last summer, redid the engine, and am now pulling it a bit. I haven't touched the rearend, other than I know it has some oil in it(it leaks onto the trailer when hauling from the axle seal). When driving it, it sounds really rough in the rearend, and it's pretty hard to push around for a tractor that only weighs 3600 pounds. Lots of noise comes just form the belt pulley - assuming the bearing could use a little attention. Other than that, are these rearends usually noisy? At some time I'd like to take the rear plate off and take a peak inside sometime just to see what it looks like in there with sprockets and chains instead of gears - anything I should look for in particular for wear? How hard is it to get bearings and seals for these?
Thanks!
