Older Case tractor
Norv
11-05-1999 19:44:34
How do I find out the age of an older Case tractor. I was told it was built around 1954.
This tractor has a front end loader and I want to know if the hydraulic unit takes regular oil or hydraulic fluid.
Mike from Canada
11-26-1999 11:43:25
 Re: Older Case tractor in reply to Norv , 11-05-1999 19:44:34
My local Case/IH dealer said that Hy-Tran was acceptable for my '49 VAC you may want to double check with yours. #20 engine oil in a hydraulic system could be bad for seals or o-rings if they have ever been replaced.
Jerrie Lot
11-09-1999 16:49:08
I have a 1951 VAC and the owners manual calls for 20weight hydraulic oil. I think any tractor that new will use some type of hydraulic oil but not the same type as you would use in something built in the late 60s or so.
gk
11-06-1999 21:29:44
1954 was and odd year for serial numbers and you could be confused as to which system to use for finding the year of your tractor.
Check our page at www.geocities.com/caseworld/caseworldyear.html
If this doesn't help email us direct to [email protected]
