case 350 - Push Rod 101 ????
ranger chris
04-02-2006 01:03:05
good call on the push rod diagnosis george and ed !!!!! took the cover off and there she was, bent !!!!! can someone give me a quick instruction on the best way to replace it??? do i need to remove the rocker?? once again, any help is greatly appreciated !!!!
ranger chris
04-02-2006 18:44:35
 Re: case 350 - Push Rod 101 ???? in reply to ranger chris, 04-02-2006 01:03:05
could the use of ether do this????
george md
04-03-2006 09:47:04
 Re: case 350 - Push Rod 101 ???? in reply to ranger chris, 04-02-2006 18:44:35
chris, Had a local contractor with a 450 and had an operator on it . On very cold mornings when the operator didn't want to sit on the tractor in the cold, he
would give it a big dose of ether and it always would bend a push rod . Then he would sit in the warm pickup till the service truck got there to fix it. My buddy with the service truck after several times of this carried push rods in the truck.
george
wilson
04-02-2006 18:01:29
Cambolted is correct as to proper procedurs , however I have loosened the tappet adjusment completely , flipped the rocker over center and replaced a push rood without removing the rocker arm shaft. If its on one end of the shaft( number one or four) renove the cotter pin and slide rocker off . The most important thing is to determine why it bent!!!! as normal valve action will seldom if ever bend a straight pushrod.
Camboted
04-02-2006 07:35:43
Yes, you need to remove the rocker arms and then replace it. First though, do you know what made it bend? It is usually a stuck valve. Is that fixed? Then, if you have a really good flat anvil, or other surface, you can try to straighten the rod if it is not kinked. Keep rolling and tapping it until it rolls true. Re-set the rocker arms and you should be good to go.
