Case VAC 44 and 48 seals and gasket kits
TSS
04-01-2006 19:19:15
Can only find engine gasket and seal kit. Need to find all the other seals and gaskets I will to put them back together fresh. Are they not available and I need to make certain ones or what. Thanks for any help!
C. Amick
04-03-2006 09:34:56
 Re: Case VAC 44 and 48 seals and gasket kits in reply to TSS , 04-01-2006 19:19:15
Go to the web site link below and click on the VAC seal list. Hope this helps.
Walt Davies
04-02-2006 12:52:37
First check with your local Case dealer alot of parts ares till available if he won't look them up for you then try another dealership.
Second take the seals to a bearing and seal store they can match them up for you. Walt
