Leaking fuel tank on Ag Untility 430.
Jim Gundlach
04-01-2006 13:54:46
I've had a leak in the diesel fuel tank on my 430 since I got it. I took the tank off and sandblasted to clean it up before priming. I find a leak at the shut-off valve and it seems to be seeping under the straps that hold the mounting bolts. Does anyone have experience with these fuel tank lining kits and know if they would seal any cracks. I will try looking in with a light to see if I can see. If that does not work, anyone knows where I might find a good diesel fuel tank for a 430 Agricultural utility tractor?
Tom (Ks)
04-01-2006 14:53:48
 Re: Leaking fuel tank on Ag Untility 430. in reply to Jim Gundlach, 04-01-2006 13:54:46
Some of the guys at the shop fixed tanks, you make sure the tank is power washed with soap real good. Then pour in the red sealer and rotate the tank around so it gets a good film in it. After it sets up, pour it out and let it dry good. You can get it at auto part stores anywhere. Tell them what you want to do and they will know what to get.
