Rebuilding Main Bearings?
Doug Lyman
03-30-2006 17:09:33
I can not find 20 over main bearings for my Case SC. Where is the place to have them rebuilt? Is it recommended? What is the turn around time?
C. Amick
03-31-2006 09:31:57
 Re: Rebuilding Main Bearings? in reply to Doug Lyman, 03-30-2006 17:09:33
Don L. will sell you a set of reconditioned ones. He probably has them in stock. He will want your old ones on trade. Contact him at [email protected] or 507-433-0073 mornings in MN.
D boll
03-31-2006 05:47:20
I had Harken Machine in Watertown, SD do my SC mains years ago, I see no problem having them relined, bearins are the same throughout the production run as far as I know
Camboted
03-30-2006 22:12:47
I could make you a new set if I had the block and crank. Do all SC's use the same rod and main bearings?? I think there were some changes.
stout1
03-30-2006 21:02:12
What engine does the SC have in it, isn"t it the same as the VAC? If so there are new mains available, I just purchased a set.
Michael
