looking at a vac tomorrow, and others
souNdguy
03-30-2006 11:53:23
I'm looking at a vac tomorrow.. and possibly a couple other similar int hat class.
I don't own anything like it.. but have been on trikes with hand clutches.. like my JD-B. What are things I need to look / look out for.
(thanks)
Soundguy
C. Amick
03-31-2006 09:36:07
 Re: looking at a vac tomorrow, and others in reply to souNdguy, 03-30-2006 11:53:23
If you look through the tractor photos in the Galleries Section of this web site, it may help you figure out what model tractor it is.
Walt Davies
03-30-2006 19:35:52
the Vac is a nice medium size tractor with 16.98 Hp. Weight would be 3199 lb. Maximum pulling weight in low gear is 2394.
Look for an Eagle hitch this is Cases answer to the 3 point Ferguson hitch. Also check the serial # to tell what year it was made don't trust the seller they are almost always wrong.
Take the first two numbers and substract 4 to get year.
51 - 4 = 1947. Look on the engine side of the bellhousing to find the serial #. Should be on the left side of the tractor and will either begin with or end with VAC and have 7 digits.
I can send some pics of differant tractors if you would like to see them. Also I have a book on the magneto that's important because the regular manual doesn't have anything on them. I can send you copies of it. You can get carb parts for this tractor and I reccomend that you do this and rebuild the carb before you do anything else. It will save you a lot of trouble later on. These tractors will run all day if setup correctly and in good condition. the timing is set by the points in the Mag my book will tell you how to do that. Walt
souNdguy
03-30-2006 21:14:37
 Re: looking at a vac tomorrow, and others in reply to Walt Davies, 03-30-2006 19:35:52
I know what you mean about year and prev owners. Every ford I've bought save one, the prev owner gave me wrong year info... pitiful part is all they had to do was lookup the sn.
Soundguy
dctom
03-30-2006 15:58:40
VAC's are not hand clutch, foot clutch only they are a very gritty little tractor and very easy to handle you wont be sory for having one
souNdguy
03-30-2006 21:17:29
 Re: looking at a vac tomorrow, and others in reply to dctom, 03-30-2006 15:58:40
Hmm.. maybee it's a DC I'm looking at. I'm pretty sure it has a hand clutch.. owner only knows it is a case.. etc.. I'm just guessing at model..
Soundguy
Walt Davies
03-30-2006 22:38:57
 Re: looking at a vac tomorrow, and others in reply to souNdguy, 03-30-2006 21:17:29
The D series tractor will give you around 35 to 37 Hp and weigh just over 7000 lb. It twice the tractor as the V series.
Walt
A nice tractor for pulling if you set it up correctly.
Get an LP head and raise the compression also oversize pistons and some little things like setting the RPM up and it will pull pretty strong.
Walt PS Let us know how you come tomorrow.
Ken in AZ
03-31-2006 21:54:00
 Re: looking at a vac tomorrow, and others in reply to Walt Davies, 03-30-2006 22:38:57
Slight correction, Walt. When the D was tested at Nebraska (Test 349, June 1940) it DID weigh 7000+ pounds but 2200 of that was added weight (343 pounds of water ballast and 764 pounds of cast iron weights per rear wheel plus 99 pounds iron weight for each front wheel). Figure it"s about a 5000 pound tractor plus weights... I haul mine behind a Blazer.
Isn"t 7000 more like your LA? I want one but don"t have anything big enough to tow it home with.
The the mystery tractor could be a S too.
Ken in AZ
souNdguy
03-31-2006 20:43:22
Looked at quite a few today..( nothing raised my eyebrow much.. ) will also be looking tomorrow.
will post back
Soundguy
