Stuck Transmission Plug
Jerry
11-05-1999 07:29:14
I recently bought a Case 311 tractor. It sat for several years. I drained all the fluids and replaced with new, except for the transmission. I can't get the plug out. Any ideas?
In addtion the valve control arm going into the hydraulic pump to raise and lower the eagle hitch is broken. Anyone have this part?
Thanks
C. Amick
11-05-1999 09:42:32
 Re: Stuck Transmission Plug in reply to Jerry, 11-05-1999 07:29:14
Sometimes vibrations will help loosen stuck plugs. Might try tapping it with a hammer or find a way to attach an impact wrench to it. I guess if you can't get it out, you could pull the PTO assembly out and use a suction gun to remove the old oil.
