CASE PLOW ID
muggsw6
03-27-2006 07:47:49
I purchased a 4-bottom, pull-type, hydralic plow this weekend. I am guessing this is one of the last pull-type plows case built as it is all flambau red in color.It has a beam frame, and 3-piece moldboards. Any ideas as to model #??? thanks in advance Mark
c hess
03-27-2006 16:20:29
 Re: CASE PLOW ID in reply to muggsw6, 03-27-2006 07:47:49
Forgot to say it is a MODEL A if it has (I) beams- some would have forged beams at rear going to bottoms. If it is a flat beam it would be a CH44 OR a Cht44 if atrip bottom
muggsw6
03-28-2006 06:29:34
 Re: CASE PLOW ID in reply to c hess, 03-27-2006 16:20:29
This plow has what I would call shear bolt(flat plate but not toggle trip) bottoms, so that makes it a CH44 I guess. Thanks for the info c hess. mark p.s. this plow appears to have not plowed very many acres but was left sitting outside long enough that the shears were in the dirt, they are very badly pitted , so i am going to replace them and just wire wheel the rest and see if I can get them to dirt scour. We'll see how tough my old sw-6 really is.LOL I'm really going to scour it behind a 806!!!
c hess
03-27-2006 08:33:48
If it was one on e-bay it was a Case Ah-46.(adesignating model-h-for hydraulic-4 indicating bottoms an 6indicating 16in
c hess
03-27-2006 08:33:02
muggsw6
03-27-2006 09:03:02
 Re: CASE PLOW ID in reply to c hess, 03-27-2006 08:33:02
No, but it is nearly identical w/the exeption of being 14",and not nearly as well kept.So,that being the case, this would be an aH-44, correct?
muggsw6
03-27-2006 09:00:39
c hess
03-27-2006 16:13:11
 Re: CASE PLOW ID in reply to muggsw6, 03-27-2006 09:00:39
Correct on model .Your a lucky fellow to find it!
