CASE SC or DC
NICK D
03-27-2006 06:47:02
I am new to Case tractors. What is the difference between a DC and SC Case tractor? They look pretty much the same in the ones I have seen. Thanks
MJ in the UK
03-28-2006 04:13:05
 Re: CASE SC or DC in reply to NICK D, 03-27-2006 06:47:02
During the Second World War Case sent to the UK the DEX tractors on the lease lend scheme. DEX was the export version of the D but I do not know the differance. MJ
DBoll
03-27-2006 14:10:30
The C does not denote a front end style it stands for "cultivator" hence a tractor intended for row crop work.
C. Amick
03-27-2006 09:13:57
The engine is a DC is around 100 cubic inches larger than the engine in an SC.
Mathias NY
03-27-2006 09:04:47
Here is a rough comparison for physical size and power:
Case SC = Farmall H = John Deere B (mid 20's Hp)
Case DC = Farmall M = John Deere A (mid 30's Hp)
Just in case there is any missunderstanding, these are not exact numbers. I relaize that the horsepowers of these tractors did change during their production runs, but for a cursory comparison it may be helpful.
jal-SD
03-27-2006 07:05:53
They look similar, but there are a lot of differences. SC is a little smaller, its less powerful, & it has a sheet metal grill. A DC's grill is cast iron, its battery box is above the dash while an SC's battery is under the gas tank. There are other differences, but this will give you a start. (My $0.02 worth. jal-SD)
NICK D
03-27-2006 09:17:06
 Re: CASE SC or DC in reply to jal-SD, 03-27-2006 07:05:53
Thanks for the reply. Does the "C" in the model refer to the narrow front end. I have seen Case C tractors with wide front and the "CC" with narrow. How do the "C" tractors fit in the size range?
Mathias NY
03-27-2006 10:27:43
 Re: CASE SC or DC in reply to NICK D, 03-27-2006 09:17:06
'C' series tractor predated 'D' series tractors. Many componets are similar or the same. If the letter 'C' follows a 'C' or a 'D' it does mean the narrow front end. The second letter in a name commonly denotes the specific package the tractor was purchased with, some common ones are below:
'DC', 'DC-3' = Row crop, narrow Front (or adjustable wide front)
'DC-4' = Row Crow, non adjustable wide front
'D' = Standard Tread
'DO' = Orchard model (low profile version of a 'D')
'DV' = Narrow version of a 'DO'
'DI' = Industrial model (heavy duty version of a 'D'
'DE' = Power unit only
NICK D
03-27-2006 13:17:45
 Re: CASE SC or DC in reply to Mathias NY, 03-27-2006 10:27:43
Thanks for you help.
