4890 head
4 R's
03-25-2006 10:15:22
Put new headgaskets about 3 months ago and now leaking in 3 different spots. heads and the block looked fine. any suggestions on why the head gaskets could be leaking in a short period of time? any help would be appreciated!
John Saeli
03-25-2006 12:49:23
 Re: 4890 head in reply to 4 R's, 03-25-2006 10:15:22
Did you Re-Torque the heads? Proper procedure is to back each not, or stud off 1/4 turn, then come back up to spec, when warm.
4 R's
03-26-2006 17:36:47
 Re: 4890 head in reply to John Saeli, 03-25-2006 12:49:23
followed shop manual when installing the first headgasket. taking heads to the machine shop tom. to see if they need resurfacing. does any one know if they have any updates to the motor in a 4890, such as headgaskets?
dwag
03-25-2006 17:52:24
Backing off head bolt to retorque is not proper procedure, but a sure way to cause a blown head gasket. Speaking from experience.
Lamont
03-26-2006 14:33:28
 Re: 4890 head in reply to dwag, 03-25-2006 17:52:24
Mine leaked every time until I did it that way. No leaks since. Speaking from experience. Maybe you weren't doing it warm.
John Saeli
03-25-2006 19:14:00
Word for word, rite from the CASE Shop manual. Standard procedure here, & never a blown head gasket.
dwag
03-26-2006 16:13:10
 Re: 4890 head in reply to John Saeli, 03-25-2006 19:14:00
Backing off the head bolt can change the crush\seal of the fire ring, especially the 504"s. I USED to do the back off & torque procedure as you guys suggest. Having the cyl head check for flatness is a must, especially on 674"s. Was that done?
dwag
03-25-2006 12:33:21
The heads should have been checked\resurfaced the first time. After resurfacing, the mach shop may have to cut circle grooves on head surface deeper. Not all mach shops are able to do this.
