kirk in ks,
03-25-2006 04:56:39
Re: Tractor,s Tractor,s,? in reply to JoelV, 03-24-2006 10:22:50
Hi Joel, Yes, the hub,s are different,on H,and M wheel,s, And the rim is too, It has y shaped bolt hole,s on the m, and h,s where the W-6 is a 3 piece curved spoke hub with small square tabs holding the outside rim on, this W-6 of mine is in ok cond mechanicallly, But the way someone welded tab,s onto the top of front axle so it wouldnt move under weight from a loader is really dumb, and now I have to jack tractor up to let axle hang to knock them off with a hammer, Cutting a hole in the front of hood is another glitch,to make room for a 12 volt alternator, areghhhh! The res,and the lever for hydralic,s is gone, Hoses go from the pump in front, along the side to the tank under the gas tank,and that,s it. the stancion is in back under the seat to hold the hoses,but no hose,s,& no lever beside laft side of seat, Joel,It seem,s the more I get into this thing, the more there is to undo, I said in yesterday,s letter about all the stupid junk this guy put on the tractor, Like strip iron to make axle stronger,and welding a tab onto the r/ steering arm that,s connected to this silly steering cylinder on R/ side of tractor,that,s in turn welded to the radius rod on R/side of tractor, Ohh Man,I I think Ill just take all this junk off, and start over, Either that,or just get something like a clean M,and be done with it. Hey Joel, Ill send you a picture of this thing If you want,and then you can see it for yourself. I dont know wheather to laugh, or to go down to the place that it was in , and find the guy, and strangle him?
