Case 311 Trans fluid
John Plummer
03-23-2006 17:27:38
Can anyone tell me what the proper fluid is for the Case 311 transmission, rear axle, and hydraulic system? Is the same fluid used in all? The fluid I drained seems very thin and has a dark reddish tint. Thanks.
Roger 300
03-24-2006 05:06:21
 Re: Case 311 Trans fluid in reply to John Plummer, 03-23-2006 17:27:38
John; The service chart says the oil for the torque tube, also the hydraulic oil, where the triple range is, takes 12 qts. of 10w-30w of motor oil or the alternative is type A automatic transmission fluid. The transmission and diffferential 90W extreme pressure gear lubricant, 24 qts. If you want to send me your address I'll send you a copy of the lubrication chart with the capacities and intervals for the 300 tactors. Roger-- I forgot to open my email, sorry.
Roger 300
03-24-2006 05:03:55
